Fuel Injector Question
trwebb26
Done lots of reading.... read the sticky a million times. It does a good job of explaining diameters for if you want to buy injectors from a car out there - but I'd like to buy a set aftermarket. If you go to http://www.fiveomotorsport.com/Injector_SetsMODS.asp#denso
then you see lots of perfectly good injectors for sale... but none specify what vehicle they are compatible with or what O-ring size they fit.
Is there a place I can do more reading - or can somebody reccomend a place where I can cross-reference new injectors to their dimensions?
The end goal is to find a set of 11mm o-ring injectors that fit into an N-42 manifold... somewhere between 370cc and 500cc. Are the Bosch Green tops on the link above 11mm and will they fit?
