thomas45 Posted June 21, 2009 Share Posted June 21, 2009 Hi guys I’m working on a 67' ChevII and I’m doing a custom 3 link on it. Im replacing the frame rails and adding a cross member to mount the links to. Now I have the x member and the frame rails tacked in. I was looking at the whole deal and it looks like I can drop the whole pig out. My question is: now that I have the rear rails and x member tacked and measured out for the car, can I remove the whole unit and complete it out of the car? Or should I just weld it up in the car? Some of the parts I need to get to and weld are very hard to reach, this would make it alot easier as you can imagin. Request assistance please Quote Link to comment Share on other sites More sharing options...
cockerstar Posted June 21, 2009 Share Posted June 21, 2009 The more you can weld in the car, the truer the end product is going to be. I'd go a bit beyond tacking everything up before I would feel safe about unbolting everything without fear of anything shifting on me. As a side note: How did you find hybridZ? Quote Link to comment Share on other sites More sharing options...
turbojohnny Posted June 21, 2009 Share Posted June 21, 2009 as previously stated, i would weld as much as you can on the car as the heat will tend to distort your parts, so unless you have a jig to hold everything in place where it needs to be i would weld as little as possible outside of the car. Quote Link to comment Share on other sites More sharing options...
