Brake Booster question
Hey guys,
I am trying to diagnose a brake problem I am having. I have noticed with the 240 that the brakes have always felt wooden. I always thought it was because of the pads, or just old brakes. But after doing more analysis I think it something more than that. I have the vented toyota brakes up front and 280zx brakes in the back. I have a proportioning valve and all new fluid. I have been finding that my RPM's go up when I am sitting at a light, and my foot is on the brake. I thought the valve going to the intake was going bad and did some tests. It is working fine. I also checked for leaks in the hoses and can't find any. I am assuming that this must mean that the booster is going bad. I have also found that there is not a big difference when the valve was hooked up one way or the other. Again, to me this means the booster is not working, and I basically have no power brakes. Am I correct in my analysis, or could there be something else I am not thinking of. I just don't want to spend $120 for nothing. Thanks.
I remembered that the 280Z and the late 240Z booster should be the same so I used the one from my project 280. I pulled that one out cleaned it up put some semi gloss black on it (gotta make it look nice) and bolted it up a few hours latter. No more RPM rise. I will have to see if the bakes feel a little less wooden tomorrow. Tonight I am redoing the drivers seat so it is a little lower so I can get a helmet on to autocross this thing.;)
Be sure you have the vacuum hose check valve in correctly. My brakes were also very hard for power assist. I found that the PO had installed that valve backwards. Once corrected it would lock the wheels up with relative ease. I also used a 280Z booster in my 71 240Z but it did require drilling a new mounting hole pattern in the firewall.
ezzzzzzzz,
That is what I thought. I switched the valves both ways and no real improvement. The one way was a little better and made the RPM's rise when on the brake.
I have since switched my booster and proud to announce that the brakes are now AWESOME. I don't know if Mike ever had properly working brakes, but these things are incredible now. I know I never had either Z work this well, so I am very happy. It only cost me some time, so that is the best part.
  • 5 years later...
