no spark... help please
7MGFORCE
hi
so i decided to follow this site for my ignition system.
http://www.carbdford.com/tech/HEI/hei.htm
i basically used the stock wires that went to the stock coil. so i used the possitive output and the negative/tach output.
when i crank the car i didnt get any spark what so ever. im curious why it does not work. i have tripple check everything and all connections are good but again no spark.
any sugestions?
side questions the dizzy has a vacuum nipple where do i connect it?
FYI: this is on an early 74 260z. with a 1990 mustang 5.0 that is carb.
The ballast resistor is the white looking rectangle next to the coil with 3 wires right? Well I connected the 3 wires and tried again. The possitive on coil drops to 8.x during crank prolly bc of starter drain. Still no spark though. Btw is the negative/tach on coil suppose to have 12v ? Mine has a possitive output.
Edit after regrounding everything I was able to get spark. But it's very very weak spark. I could barely see it. I used the main spark plug that connects to the coil as my tester using ascrew driver. Btw how many spark per second am I suppose to see? Bc when it was being crank I could only see 1 every few second I would thing it would be more per second when cranking bc it's a v8
  Mike kZ said:
Do you have a Duraspark distributor? That article says you need one.
The voltage dropping while cranking is normal.
Does the engine block have a good ground to the frame or battery?
Yes I do have duraspark dizzy. The car now have spark and I made sure The grounds are solid and I ground the engine and chassis.
My question is, is it normal to have a weak spark when the engine is just cranking?
I have to sort out my pump wiring before she start unfortunately so I can't see how the spark is when running
