Does my motor have a stock cam?
1hr40
Sorry no picture.
My car has a bit of a rough idle that I cannot smooth out. It also doesn't start to really accelerate until 2500 rpm or so.
The cam has JAPAN cast into it, an H and also E30. I could not find any other markings other than a 1cm square block also cast into the camshaft.
Is this a stock cam?
Thank you,
Michael
  • Administrators
Using your shop manual, (even the Haynes manual), and/or if you’ve done any research then you would find the lift figures for the stock cams. Armed with that information and a pair of cheapo dial or vernier calipers, you can measure the cam lobe in two places, one over the nose of the lobe and the other 90 degrees, or perpendicular to that for the base circle. Subtract the base circle measurement from the nose-of-the-lobe measurement. Now multiple that by 1.5 for the rocker ratio. Then subtract the stock valve lash clearance of .010”-.012". Now that number should close to .393"-.413" which is the stock L-series valve lift. If your number is greater than that, chances are pretty good it is an aftermarket cam. If it less?...
