Beau M Posted July 18, 2009 Share Posted July 18, 2009 So, I think that this is the plan for the Alsil mounts correct? My question is about the "notes". Can someone explain them? What is supposed to be 1" and 7/8" away from what? The hole from the bottom of the bracket? I take it this will tilt the engine a bit? Quote Link to comment Share on other sites More sharing options...
alsil Posted July 23, 2009 Share Posted July 23, 2009 All the notes in white are mine. The notes in red were added by someone. This is an old design, and after the engine sat on the frame rails for a little bit it began to twist the rails, and the engine dropped almost 1". I designed a new one with 4" square tubing that just used the rail to bolt to. I wouldn't use the seperate mounts unless you reinforce the frame rails substantially. Quote Link to comment Share on other sites More sharing options...
