A few questions (RB26)...
Juicehead
Ok, I think I have read through most of the stickys...
I am trying to budget a possible swap and have a couple questions for an install.
1. What mods are required for the following:
400-500hp
500-600hp
600-700hp+
2. I think I missed it, but what transmission is being used for this motor?
3. Would 500hp be a reliable daily driver? I do not want to be working on this thing 5 hours for every 1 hour of drive time. It then becomes more like my airplane, and that is bad enough...
For 400whp you need more boost, bigger injectors, and a good tune. For 500whp you need bigger turbos, bigger injectors, and a good tune (maybe cams if you want better response). That should be reliable if the motor is in good condition. For anything more than that you need to go into the bottom end...
perfect, thanks....
I managed to find the other answers by digging a bit more...
