badjuju Posted July 26, 2009 Share Posted July 26, 2009 I'm having a hell of a time trying to figure out how to connect who to what. The following documentation is for my summit harness: http://static.summitracing.com/global/images/instructions/sum-890020.pdf I'm referring to the 240 diagram here: http://album.hybridz.org/showphoto.php?photo=2126 So far as I can tell, I need to run two of my lights in paralel, but I can't tell which ones! From the summit PDF you'll notice I don't have a wire for my brake lights. Does this mean I need to run another wire seperately and bypass the deal all together? I've been locked here for a couple hours, and I'm ready to just frisbee this little bastard laptop into the lake, so I'd appreciate any help you guys can offer. Quote Link to comment Share on other sites More sharing options...
badjuju Posted July 26, 2009 Author Share Posted July 26, 2009 Turns out the $whatever difference between the summit and painless harneses is the extra manual pieces that come along with the painless stuff (along with anything that other people have noted). I ran to my neighbor's place, copied his painless manual, and everything is falling into place. I'll post my notes later on in the project. Quote Link to comment Share on other sites More sharing options...
Dudeboy Posted August 2, 2009 Share Posted August 2, 2009 I had the 18 circuit Summit harness !!!! terrible instructions !!! Turn signal and brake lights are a combination lamp. Also when you look at the summit instructions, you will see two white brake switch wires ( one white wire in the dash section and one white in the column) and a orange brake switch power. The white brake switch wire will connect from the brake switch to the turn signal switch. Like you, I got the Painless and the Kwikwire instructions to make since out of the summit harness, called Summit told them I had problems with my harness and fuse box, so I removed it (did not cut anything) and they gave me a refund for it. I have since bought a 8 circuit Kwik wire harness that I will start on next week. I personally could not make the 18 circuit Summit work for my application, plus the terrible instructions and fuse panel issues. Good Luck if you can make it work for you. Quote Link to comment Share on other sites More sharing options...
badjuju Posted August 3, 2009 Author Share Posted August 3, 2009 Thanks sir. I'm right now working on a wiring diagram for it, i've got the front and rear lights wired in. lol Quote Link to comment Share on other sites More sharing options...
