Noddle Posted August 9, 2009 Share Posted August 9, 2009 Hi, I'm having a issue calibrating my TPS running MS2Extra 2.1.0p at no throttle, the 'Get Current' value is about 120 and at full throttle its about 800 I didn't have any problems when I was running MS II 2.88 code earlier in the day. Nigel Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted August 10, 2009 Share Posted August 10, 2009 Those values sound quite normal for an MS2. Are you having other problems with the TPS? Quote Link to comment Share on other sites More sharing options...
Noddle Posted August 10, 2009 Author Share Posted August 10, 2009 Hi, If I try to except the 800 ish value (full throttle), it says it's expecting 250 / 255 it's not in front of me at the moment, and If I accept that value, the throttle gauge will only move about 0 to about 7 % from no throttle to full throttle. Nigel Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted August 11, 2009 Share Posted August 11, 2009 250 to 255 is a typical maximum value for MS1; MS2 will go a lot higher. Just accept the values the screen gives you. Quote Link to comment Share on other sites More sharing options...
Noddle Posted August 11, 2009 Author Share Posted August 11, 2009 250 to 255 is a typical maximum value for MS1; MS2 will go a lot higher. Just accept the values the screen gives you. Hi, I have moved from MS II 2.88 to MS II Extra 2.1.0p, with MS II 2.88 I didn't have any problem, but with Extra, it thinks a value of 800 is to large, It think 250 - 255 is the maximum it wants, so if I except that value, the TPS gauge in Megatune will only move 0 to about 7 percents for closed to full I hope I have myself clearer.. Nigel Quote Link to comment Share on other sites More sharing options...
Noddle Posted August 13, 2009 Author Share Posted August 13, 2009 Hi, I had another crack at doing the full throttle TPS calibration, the get value was 821, and this time it excepted the number, and also now my throttle gauge works from 0 to 100%. I'm not sure what happened, but it's working now, so I'm happy.. Nigel Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted August 13, 2009 Share Posted August 13, 2009 Were you getting an error message of some sort? If so, could you please post a screen shot of it? Quote Link to comment Share on other sites More sharing options...
Noddle Posted August 14, 2009 Author Share Posted August 14, 2009 Were you getting an error message of some sort? If so, could you please post a screen shot of it? I did get a message originally, but when I tried last night it worked fine, I didn't think about capturing the message when it first happened, so I can't show you, If it every happens again, I'll capture it. Nigel Quote Link to comment Share on other sites More sharing options...
