Guest 400 ci 280z Posted January 24, 2002 Share Posted January 24, 2002 i am totally stripping my 280z and was in the process of getting the harness that goes through the fire wall on the passengers side. i was just wondering how do you get the blue, white and black connectors from the big white block? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 24, 2002 Share Posted January 24, 2002 when i removed the harness from my 240 i had pullit inside the passenger compartment,i had the dash out also, that helps a lot Quote Link to comment Share on other sites More sharing options...
Guest 400 ci 280z Posted January 24, 2002 Share Posted January 24, 2002 those big fusible links wont fit through the fire wall though Quote Link to comment Share on other sites More sharing options...
jeromio Posted January 24, 2002 Share Posted January 24, 2002 I was able to remove the wiring harness by pulling it thru to the engine compartment. You just have to push each individual connector thru one at a time, they do fit. Not a problem reconnecting either, since I think there are only 2 pairs of connectors that are similar and confusible, so, just mark one of those pairs with paint or something. I've been contemplating re-doing that front harness. Waytek has some really nice water proof automotive connectors. Problem is that I'd like to get multiple different kinds to duplicate that "can't make a mistaken connection" system, but they have pretty hefty minimum quantities. It'd be key if we could maybe arrange a group purchase or something. Quote Link to comment Share on other sites More sharing options...
Guest 400 ci 280z Posted January 25, 2002 Share Posted January 25, 2002 i found the post i was looking for and i got the harness out of the car. you just had to give the blue connector a good wack with a hammer or something then i just sliped the couple connectors through to the engine compartment. Quote Link to comment Share on other sites More sharing options...
