alsil Posted February 13, 2002 Share Posted February 13, 2002 So I want to wire up my messed up turn singal wiring. My switch is brand new, so I want to make a seperate harness since I have pretty much replaced most of the stock harness already. I have most of the wiring figured out, I just need to know about the switch. Is it a switching ground, or just redirecting current? I don't think it's a switching ground because the flasher has to be before the switch in the circuit, but you never know with Nissan wiring. So so far, here's what I have: 12+ from battery -> fuse box -> flasher -> switch -> right or left lights -> to common ground Does that sound right? Also, I assume there are only 3 wires I need from the switch, the 12+ feed and the two wires for the lights. I am not using the brake lights in the circuit, I'm doing that seperate. Thanks AL Quote Link to comment Share on other sites More sharing options...
DavyZ Posted February 14, 2002 Share Posted February 14, 2002 bump Quote Link to comment Share on other sites More sharing options...
