Turn signal switch wiring
alsil
So I want to wire up my messed up turn singal wiring. My switch is brand new, so I want to make a seperate harness since I have pretty much replaced most of the stock harness already.
I have most of the wiring figured out, I just need to know about the switch. Is it a switching ground, or just redirecting current? I don't think it's a switching ground because the flasher has to be before the switch in the circuit, but you never know with Nissan wiring.
So so far, here's what I have:
12+ from battery -> fuse box -> flasher -> switch -> right or left lights -> to common ground
Does that sound right? Also, I assume there are only 3 wires I need from the switch, the 12+ feed and the two wires for the lights. I am not using the brake lights in the circuit, I'm doing that seperate.
Thanks
AL :D
