Guest Anonymous Posted July 12, 2001 Share Posted July 12, 2001 Can anyone help with the answer to decrease the amount of header roasting in my 250 GTO Chevy 350. Can make scrambled eggs and boil water for tea in my carburator-it gets so hot Any recommendations for a block huggar header that FITS w/o modification?? Sanderson's do not fit. Chicken Soup for the Hybrid Owner- Cappy Quote Link to comment Share on other sites More sharing options...
SpeedRacer Posted July 13, 2001 Share Posted July 13, 2001 Robert - how about posting a pic of your GTO? I use Hooker block hugger with ceramic coatings coatings on my GTO with a 327 SBC, (see "Featured" cars off of main page here). Of course you must be using the JTR or similar method that places the engine back near the firewall. As Lone said, ceramic coatings really do help a lot. Also, make sur you run enough timing advance because retarded time will cause excess head in the headers. You've seen the pictures with the engine running on a dyno with glowing headers - it's done by retarding the timing. Also make sure it's not running to rich. Quite often an extra rich mixture will continue to burn after it leaves the cylinder and cause excess heat as well. BTW, Sanderson http://www.sandersonheaders.com/ makes about 30 different headers for a SBC so I think you can find one to fit. Quote Link to comment Share on other sites More sharing options...
Guest dankinzle Posted July 13, 2001 Share Posted July 13, 2001 Sanderson qp1000 fits pretty well. I have some pics of them on an engine, but I ran out of server space for the ones of the engine in the bay. http://www.geocities.com/mandryd/qp1000.html Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 13, 2001 Share Posted July 13, 2001 The members here use quite a few different brands of block huggers, although Hooker is one of the ones JTR suggest, I used Heddman because they were cheap. Have you tried ceramic coatings on the header? This is supposed to reduce temps. FWIW. Regards, Lone Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted July 15, 2001 Share Posted July 15, 2001 Well, I bought Flowtech ceramic coated from Jegs for less than $200. Mikelly pointed me that way. They fit great. But, they are not big pipes, 1 1/2" I think. I'm running a stock 305tpi, so should be fine for me. If your running big hp you may be looking for bigger pipes. Seems to me that there was a thread here that referanced a page that dynoed verious size headers on verious engines. Not a lot of advantage to bigger pipes on most applications as I remember. Quote Link to comment Share on other sites More sharing options...
