Guest thomo5150 Posted August 22, 2009 Share Posted August 22, 2009 Hi looking for the dimensions of a VQ35DE engine. Bottom of the sump to the top of the cylinder heads. Width across the heads. lenght of the engine. Thanks Tim Quote Link to comment Share on other sites More sharing options...
40flash Posted August 26, 2009 Share Posted August 26, 2009 Hi looking for the dimensions of a VQ35DE engine. Bottom of the sump to the top of the cylinder heads. Width across the heads. lenght of the engine. Thanks Tim Hi Tim - I just went to the garade to take measurements for you. Here is what I got. Overall height from oil pan to top of intake manifold....................28'' height to top of heads......................................................23 1/2'' height to top of front cam covers.......................................24 3/4'' width from head to head not including plumbing tubes............22 1/2'' overall length from front idler pully to where trans bolts up...........21'' The farthest point forward is the fan clutch assy. but most of us will remove that to go electric fan I assume. Quote Link to comment Share on other sites More sharing options...
Jared Posted August 27, 2009 Share Posted August 27, 2009 Hi Tim - I just went to the garade to take measurements for you. Here is what I got.Overall height from oil pan to top of intake manifold....................28'' height to top of heads......................................................23 1/2'' height to top of front cam covers.......................................24 3/4'' width from head to head not including plumbing tubes............22 1/2'' overall length from front idler pully to where trans bolts up...........21'' The farthest point forward is the fan clutch assy. but most of us will remove that to go electric fan I assume. Is that for a Pathfinder VQ35 ? I'm just assuming since you mentioned the fan clutch. Quote Link to comment Share on other sites More sharing options...
40flash Posted August 27, 2009 Share Posted August 27, 2009 Is that for a Pathfinder VQ35 ? I'm just assuming since you mentioned the fan clutch. My VQ is out of a 2004 G35 sedan. At least that is what I was told. Would the block and general dimensions be different? Quote Link to comment Share on other sites More sharing options...
40flash Posted August 27, 2009 Share Posted August 27, 2009 My VQ is out of a 2004 G35 sedan. At least that is what I was told. Would the block and general dimensions be different? I have never looked under the hood of a G35. Do they not have a fan clutch? Are there numbers on my engine that would identify what it came from? Anybody know? Quote Link to comment Share on other sites More sharing options...
Jared Posted August 28, 2009 Share Posted August 28, 2009 I was thinking that the g35 used electric fans like the z, will have to double check that Quote Link to comment Share on other sites More sharing options...
jeffneal66 Posted August 29, 2009 Share Posted August 29, 2009 I have a 2003 G35 VQ, and it did not come with a mechanical fan. Quote Link to comment Share on other sites More sharing options...
