Guest jimmywrights Posted August 30, 2009 Share Posted August 30, 2009 my goal is to get a nice 9.1 or so compression ration. with power from 2000- 6000 rpm's. I have a bone stock 78 Z. N42 block and N47 head. I am planning on replacing the cam with it also. the whole shebang. I don't want my rig to be crazy fast. Gaining 20-30 horsepower will make me happy. My goal is to see nice response and peppiness. I WILL NOT swap a turbo into my vehicle. It is worth more with the stock motor than with an engine that doesn't match my serial #'s. Especially since CA is gonna start checking the serial numbers at the smog shop soon. What is your advice on getting this desired setup. Quote Link to comment Share on other sites More sharing options...
kolonelklink87 Posted August 30, 2009 Share Posted August 30, 2009 you need to re-read the rules and edit your post before it gets removed... check the FAQ and read the stickies. Everyone has thier own take and approach for best results. Read around, see what takes your interest and what fits into your goals. Good luck -pete Quote Link to comment Share on other sites More sharing options...
