dwarlick Posted September 2, 2009 Share Posted September 2, 2009 Does anyone have an electronic speed sensor for the RB25 transmission. I am not getting a signal from mine. I am pretty sure it was damaged during shipping. Would have posted in parts wanted but its really kinda specific to this group. Quote Link to comment Share on other sites More sharing options...
jakeoster Posted September 4, 2009 Share Posted September 4, 2009 How'd you test it? Make sure you have the teeth on the speedo sensor lined up with the ones inside the transmission, if you installed it and tested it that way. What seems to be damaged? Mine looked beat to hell but it works well. Quote Link to comment Share on other sites More sharing options...
dwarlick Posted September 4, 2009 Author Share Posted September 4, 2009 The sensor has not been out of the transmission since I got it but the wire attachement on the end was broken off and I had to solder a wire to what was left. I have the wire hooked to the autometer speedo and when I go in to calibration mode it doesn't give off any readings which it is supposed to do. When I finish calibration mode the speedo does not work. The speedo is brand new and it does everything but calibrate. Quote Link to comment Share on other sites More sharing options...
