can someone tell me wut these are?????
Guest mtj71Z
Guest mtj71Z
this is on the drivers side
this was connected to my heater stuff before i yanked it out tongue.gif will water come out? where does that go?
this on the passenger side...looks same as the drivers side!!!!!! tongue.gif
i have no idea wut either of these are - are they even important? tongue.gif
and this thing is another '?' is that a dimmer for the dash lights??
if anyone can tell me wut these are and wut they do it would be greatly apprciated! thanks a bunch
Guest zthang43
Those first two things are push/pull handles for the fresh air vents at your feet. You can see them work if you stick your head up there; air comes from the cowl down alongside the fender and into the car.
The third pic seems to be a relay of some sort. Don't know which one; you probably shouldn't get rid of it yet.
The last one looks like a dimmer for the headlights; it should be mounted in the dash on the drivers side above the push pull lever in your first two pics.
