Guest aaronboy Posted September 26, 2009 Share Posted September 26, 2009 I have a 76 280z 2+2 first off. the problem i am stuck on is with the fuel injection. i have spark, fuel to the injectors, and plenty of air. i also have power to the injectors but they are not squirting fuel. the car runs on starting fluid fine. my dad and i have checked all the relays, fuses, etc. we think it has to be the ECU not making up the ground for the injectors. i just wanted to see if anyone had any other suggestions or ideas before i send the board in. Quote Link to comment Share on other sites More sharing options...
240fox Posted June 30, 2012 Share Posted June 30, 2012 Did you ever figure this one out? Im having to the same problem. I swapped an l28e into my 71 from a 77 and im not getting squirt. My spark plugs aren't getting wet. Quote Link to comment Share on other sites More sharing options...
Vonlam43 Posted August 27, 2012 Share Posted August 27, 2012 Lots of good info in this link live by the EFI bible it will help alot. http://atlanticz.ca/zclub/techtips/efisystem/280zfuelinjectionbook.pdf Quote Link to comment Share on other sites More sharing options...
