nismo_zxt Posted October 14, 2009 Share Posted October 14, 2009 Is this someone would have information regarding the installation of a Z31 turbo 300zx 87-89 transmission (FS5R30A) first version on L series engine? I plan to the swap to hole more HP, but don't know about the fitting. If anybody body know (for sure) if it a bolt on or not let me know. Do I need to put an adapter between the trans into the engine? Do you know if it's the same bolt pattern. Do I need an adapter? Or could I drill new hole, tap new thread without spacer? What about the main gear drive play? I should probably modify the crossmember to install the transmission. Your help would be appreciated Thanks Quote Link to comment Share on other sites More sharing options...
cockerstar Posted October 15, 2009 Share Posted October 15, 2009 Definitely not a bolt on, but Austin makes a kit to swap a z32 transmission in with some machining to the bell-housing. The z32 trans has been known to hold in excess of 500hp in stock trim http://forums.hybridz.org/showthread.php?t=154214 Quote Link to comment Share on other sites More sharing options...
