ZROSSA Posted July 1, 2002 Share Posted July 1, 2002 Howdy, Of topic as usual but I was looking at your sentra and it brought up a few Q's. Is it rear wheel drive? Seeing that is a tube chassis i am thinking the weight will be pretty close to my corrola. I am at the stage now where it is time to make anti roll bars and mounts and I was hopeing that you might be able to give me a idea where to start on thickness. I am ging to use tube with machined ends welded in. Thinking around 25 ml for the front but I have no idea what to use for the back. Most of the guys I see run very little rear bar. Mine is a beam axel with a three link and panhard bar. Weight should be around 800 kg with close to 50/50 weight split. Tires are dunlop slick 265/23/15 ,Close to that any way, on 10 inch rims. springs are soft at this stage 400 lb front 200 rear. Just a starting point. Thanks Douglas Quote Link to comment Share on other sites More sharing options...
ZROSSA Posted August 4, 2002 Author Share Posted August 4, 2002 Are You Out There? Douglas Quote Link to comment Share on other sites More sharing options...
