Can you uncover the relays without unmounting them?
TomoHawk
Are you referring to the 280Z fuel injector relay (three, maybe four relays I believe) housing; which is located on the passenger apron (inner fender well)?
If this is the cover to which you refer, that cover is made up of two maybe three pieces (I dont remember exactly) but the relays are held in place by Phillips Head Screws.
The mounting bracket to which the relay housing is connected are actually spot welded to the apron.
If this is not the relay housing you were inquiring about, then give us more info; Car, Year, Make, Model, ect, ect.
Kevin,
(Yea,Still an Inliner)
