nismoman63 Posted November 4, 2009 Share Posted November 4, 2009 Do you guys/gals know anybody running solid lifter cams in Z32TT on the street? Quote Link to comment Share on other sites More sharing options...
Tech@EPR Posted November 13, 2009 Share Posted November 13, 2009 there aren't many out there but there are a few. Are you inquiring to know about DD situations or someone who built a forged race engine and running it on the street? Give me some details as to what you are looking for. Quote Link to comment Share on other sites More sharing options...
nismoman63 Posted November 13, 2009 Author Share Posted November 13, 2009 The motor has solid lift cams(270 dur 10.25 lift),750 injectors,dual pop chargers,single mas air sensor on drivers side,JWT box set up for single mas air sensor,up dated cam gears,535 ball bearing turbos with big manifolds,and greedy blow off valves.The idle is like a 69 Z28 302,rough and hunts around.I want to know if this is normal.I have smoke checked the engine and no leaks Quote Link to comment Share on other sites More sharing options...
Tech@EPR Posted November 13, 2009 Share Posted November 13, 2009 yes you will have some lope at idle..have you checked your AIC and TPS to ensure they are calibrated correctly? Quote Link to comment Share on other sites More sharing options...
