Guest zphreek Posted September 5, 2002 Share Posted September 5, 2002 hey guys, i was just wondering if it is very common for a NEW mechanical fuel pump on a 240z (cammed, header, slightly modded SUs...) to vapor lock while running?? i used to drive a 280 and it would vapor lock practically every time i shut it off, and my 240 does sometimes when i shut if off pretty hot. but mainly if i am driving slowish while it is about 80 degrees outside it starts to do it. one time i went thru the drivethru at Mcdonalds and almost ended up pushing my Z out of the way because it started doing it. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 6, 2002 Share Posted September 6, 2002 I always considered "vapor lock' not a fuel pump problem but fuel getting hot and percolating in thr fuel line from engine heat/hot weather/close location to exhaust. I lived in the midweswt for a few years and had a truck that would vapor lock. I insulated the fuel line and then installed an auxillary S19.95 JC Whitney electric fuel pump operated by a switch on the dash. One time after a hard hot drive after stopping for fuel, it started to vapor lock, I switched on the auxilary electric fuel pump ..hit second gear and away I went . When the temperature gauge indicated things cooled down I switched the electric pump off. Only rig I ever had that would vapor lock. Quote Link to comment Share on other sites More sharing options...
