degofedal Posted November 14, 2009 Share Posted November 14, 2009 Hi I recently bought a 5 speed manual '73 240z with a stock L24 and tranny. As i have not experienced this problem with any of my previous cars before i thought some of you guys might be able to help me. I'm having having a problem when i try to quick shift from 2nd to 3rd gear - e.g. during hard accelaration. Take a look at the attached illustration. Fig. 1: when i shift from 2nd to 3rd in a diagonal pattern it results i the gears grinding. Fig. 2: When i shift from 2nd to 3rd by pushing the gearlever straight up (towards 1st) letting it settle in neutral and then put it into 3rd there's no problem. Any suggestions as to what might be the problem? Thanks so much in advance Best regards Degofedal Quote Link to comment Share on other sites More sharing options...
letitsnow Posted November 14, 2009 Share Posted November 14, 2009 Synchro is probably bad, when you shift quickly it'll grind. When you let it settle in neutral it gives the synchro time to do it's job and let it slide nicely into gear. The only thing you could do, other than replacing it, is changing the tranny oil, if it's ancient or low it could make it grind a bit or shift hard. Quote Link to comment Share on other sites More sharing options...
degofedal Posted November 15, 2009 Author Share Posted November 15, 2009 Hi Letitsnow Thanks so much for the advice - i'll run it by my car guy. Hopefully it is not to big of an "operation". Best regards Defogedal Quote Link to comment Share on other sites More sharing options...
