Trans crossmember I made
mr jdm
Hey I made a trans crossmember for my Z. I'm putting an sr20 in it and since there is lmited space between the clutch master and intake manifold I couldnt mount the motor as far back as possible unless I had floor mount pedals.
I couldnt use the mckinney trans member, so I made one. It used the an Avid racing solid mount between the trans and member. What I did was just go down and across using square tubing, Then I drilled holes in the tubing that was perpendicular to the ground. I welded a 1/2 thick rod to one side THen I used 1.5" angle and drilled holes for the mount and holes for the 1/2 rod to slide in. While I was under the car I could slide it on the rod, when it got to the sweet spot I just tacked up and welded it up. What do you think of this?
