HarrisonTX Posted December 9, 2009 Share Posted December 9, 2009 I have been considering a remote oil filter adapter. That would allow more clearance for headers, as well as let me plumb in an oil cooler. I would like to mount the oil filter somewhere that wont require clean up once the oil filer is removed... IE with nothing under it. Anyone have a good spot, with pics? Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted December 9, 2009 Administrators Share Posted December 9, 2009 (edited) Here's mine, quoted from this thread; http://forums.hybridz.org/showthread.php?t=154591 I did a remote oil filter, placed it on 45 degree angle, driver-side frame rail forward of the rack, just behind the radiator. Made oil changes a breeze and did allow a little more freedom in exhaust routing, not having to make room for oil filter changes. Here's another thread, same topic; http://forums.hybridz.org/showthread.php?t=137027 Hope that helps, Paul Edited December 9, 2009 by BRAAP Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted December 10, 2009 Share Posted December 10, 2009 Mines in almost the same place as Pauls. I mounted mine vertical rather than angled though. One of my hoses runs though the factory hole in the motor mount tower. I used a four fitting filter mount and ran my oil pressure sender off of one of the fittings (no cooler used). Quote Link to comment Share on other sites More sharing options...
HarrisonTX Posted December 11, 2009 Author Share Posted December 11, 2009 DAN Since yours has 2 ins, and 2 outs, is it ment to be used with an oil cooler or something? I plan on runnin an oil cooler also. Yours appears pretty different than BRAAPS. BRAAP! what was your reason for the angle? Thanks for the pics guys Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted December 11, 2009 Share Posted December 11, 2009 DANSince yours has 2 ins, and 2 outs, is it ment to be used with an oil cooler... Yes. Quote Link to comment Share on other sites More sharing options...
HarrisonTX Posted December 11, 2009 Author Share Posted December 11, 2009 A simple mount in front of the radiator? Ive seen oil coolers with fans, but i think that is a little over kill. Quote Link to comment Share on other sites More sharing options...
DavyZ Posted December 12, 2009 Share Posted December 12, 2009 The location where Dan and Paul have their oil filters mounted gives a lot of room. I saw Dan's in person once and was convinced to mount mine in a similar manner--the install is clean, vertical for a no-drip situation when changing filters, and easy to get to without obstructions. It appears that one can change the filter by just reaching up underneath the car. Nice. Davy Quote Link to comment Share on other sites More sharing options...
HarrisonTX Posted December 13, 2009 Author Share Posted December 13, 2009 I dont know what Dan's got going on. I realize he has an oil cooler after the filter. Why the extra in and out port on the filter mount? In my head it goes like this. unfiltered oil from the motor, going to the filter, oil leaving the filter going to the cooler. leaving the cooler going back to the engine... not... leaving the cooler going back to the filter? Ive seen this before, just never thought about it. Quote Link to comment Share on other sites More sharing options...
HarrisonTX Posted December 13, 2009 Author Share Posted December 13, 2009 Here is another option. It looks like even more out of the way Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted December 13, 2009 Share Posted December 13, 2009 I dont know what Dan's got going on.I realize he has an oil cooler after the filter. Why the extra in and out port on the filter mount? In my head it goes like this. unfiltered oil from the motor, going to the filter, oil leaving the filter going to the cooler. leaving the cooler going back to the engine... not... leaving the cooler going back to the filter? Ive seen this before, just never thought about it. Actually I don't have an oil cooler. The remote mount I'm using has the extra fittings to run one but I'm not using them for that. One is plugged and the other has my oil pressure sender mounted to it. This mount has an IN and an OUT on each side. I chose this one because the other type with only one IN and OUT have one of the fittings on top. My mount allows for a lower profile and points the hoses directly where I wanted them to go without adding an extra elbow. It cost a little bit more but not much. It was only after I had it mounted that I discovered it would be a convenient place to mount the pressure sender. That orange car is obviously well executed but oil filter changes would require some clean up. All drips from my filter changes go directly to the pan (or the floor!). Quote Link to comment Share on other sites More sharing options...
HarrisonTX Posted December 13, 2009 Author Share Posted December 13, 2009 Thank your for the information. That looks like the way i want to go. I guess it has 4 ports, just for better mounting options. I plan on running something similiar in style to yours, with the addition of an oil cooler. I plan on mine seeing extended street time, hopefully plenty of highway miles, and should see upper RPMs often. Thanks guys. Quote Link to comment Share on other sites More sharing options...
