Guest Anonymous Posted December 13, 2002 Share Posted December 13, 2002 Getting ready for a 60k maintenance on my 93 300ZX N/A. One step 'scares me' and I wanted some advice from y'all. Step reads that if you cannot take crank sproket off easily, you can score it with a air powered cutting wheel ( which I have), and then tap a chisel into it, which breaks it in half. Thusly removing it. Anyone ever do anything like this without damaging the crank end? IF so how deep to score, and how hard to chisel? Steve Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 19, 2002 Share Posted December 19, 2002 I don't know about the procedure you described, sounds scary. What I have done when the sproket is being stubborn is drill two holes 180 degrees apart and tap them with a 6mmx1.00 tap and use a puller. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 19, 2002 Share Posted December 19, 2002 Sounds like an idea. I guess you drill for about 3-4 threads worth. Steve Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 20, 2002 Share Posted December 20, 2002 I usually go 6-8 threads, less chance of the bolts pulling out. Quote Link to comment Share on other sites More sharing options...
