Konish Posted December 16, 2009 Share Posted December 16, 2009 Fellas, Anyone have pics of the original shifter hole in a 4 speed 240z tunnel? I'm at an impass with what I want to do next. I want to keep the original 4 speed console, but my tunnel was "modified" for a 5 speed conversion. I have toyed with the idea of modifying a shifter by cutting the shaft off the pivot point, flip it upside down and re-weld it to the very back of the pivot point (90* aft of the original location). I would then heat the "s" bend to orient the stick toward the exit hole. I'm not sure though that it'll be long enough to do that *and* have it exit through the hole. Or...I could use a '72 console which I'm guessing will require the fuse box to be relocated (?) Other than losing the '71 console look, it should be pretty easy. Having said all that I would love suggestions, pics etc... R/ Dustin Quote Link to comment Share on other sites More sharing options...
