I need a second set of rims for drag slicks, what do you guys use?
Guest TurboLS1
Guest TurboLS1
I am looking at getting a second set of rims to mount slicks on, I tried and tried to find a set of the same rims I have on the car now but was told they no longer exist, they are ROH reflex 16x7 offset unknown. so here is where I could use your help, I will be running 225/50/16 hoosier drag radials so the rim needs to be a 16x7 but what back space should i get?
I run a set of these in the back with 235/60-15 drag radials, they clear the big Wilwood disc brakes I'm running and barely clear the rolled fender lip in the back. Pretty cheap, not super heavy, and they come in a 16" too. They will not fit a 240z with that size tire unless you're running coil overs though, the tire barely touches the stock spring perch, they fit a 280z fine though.
http://cgi.ebay.com/ebaymotors/15x8-SPORTMAX-BLACK-501-WHEELS-XXR-RIMS-AE86-E30-MIATA_W0QQitemZ230417442571QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item35a5f3270b
Edited by Chris240zTurbo
gotta run coilovers
