Guest 73TPIZ Posted January 28, 2003 Share Posted January 28, 2003 I've installed a cyberdyne digital speedo and can't get it to work with my '86 700R4 (electric speedo sender). the instructions say the unit sees an electronic pulse from the trans while driving. i reused the original Vehicle Speed Sensor from the TA and wired it as follows: purple and yellow wires from trans, pink/black to ign on, black to grnd. the other 3 wires were to the TPI compu, cruise, and orig speedo so i took speedo wire and sent it to the cyber unit. no worky. Is maybe the vss converting a digital signal (pulse) from the trans to an analog sig and that's why the cyber unit doesn't work? if so, can i straight wire either the purple or yellow wire to the cyber from the trans? what would i give the other wire, +12volts or ground? sorry so long, but i don't want to do it and blow the cyber unit before i get some input. thanks PS: Cyber sells the speed pickup separate but i get the feeling its the old crap magnet you tape to your driveshaft and have a pickup send a sig to the unit. Plus i can't see $40 more when the factory has already done it for me inside the tranny. Quote Link to comment Share on other sites More sharing options...
Guest 73TPIZ Posted January 31, 2003 Share Posted January 31, 2003 Anyone..... Quote Link to comment Share on other sites More sharing options...
