Guest Anonymous Posted June 20, 2000 Share Posted June 20, 2000 I've seen these cheap ($50) Oxy/Propane torches at the hardware store, and I wonder if anyone has used them to cut and weld sheetmetal. Specifically, are they enough to cut out and weld in floor pans in my 280z? Quote Link to comment Share on other sites More sharing options...
Guest tom sixbey Posted June 26, 2000 Share Posted June 26, 2000 well, i dont have a concrete answer for you, but i can tell you that a friend of mine has cut throught 1/4" thick metal with one of them before - however very slowly. You tend to burn off more metal than you want to with one of them if your not practiced with one, and they create a lot of heat which could warp some of the surrounding metal. If i were you, i'd cut the floors out with some kind of grinder. - but make sure your chassis is supported underneath before you make any cuts.. Quote Link to comment Share on other sites More sharing options...
Guest tom sixbey Posted June 26, 2000 Share Posted June 26, 2000 n/c [This message has been edited by tom sixbey (edited July 10, 2000).] Quote Link to comment Share on other sites More sharing options...
