rear hatch again
ok i took the panel on the inside of car that covers rear hatch locking mechanism. the arm tha turns at bottom of mechanism to either locked in which it doesn't contact the actual latch that opens door and unlocked where it sits right above the latch and as you push down on the part you push to open door it opens the latch to then open door. just trying to give a good sense of what i am saying. the latch part presses down and all with same stiffnes as before but the door will not open. i can see teh latch arm come up when push the meachanism stuff down butt the door still wont open is there anything else that could keep the door shut
thanks
If I am reading things right, and you can for sure push down the latch part... its probably just stuck to the weatherstripping or something.
Best bet is still probably to pop off the retaining clip and take the lock out, and try fiddling with it from outside. I have no lock on mine and all it takes is a finger in the hole pushing on the lever to open it up.
"Gimme Fuel,
Gimme Fire,
Gimme that which I desire"
-Metallica
Drax240z
1972 240z - L28TURBO transplant on the way!
http://members.xoom.com/r_lewis/datsun.html
http://members.home.net/drax77/newpage.html
cool you read things right except i do have the lock out and i put my finger in on lever and it pops to point where door should open and it doesn't. hehe i had a bar on jack and it lifted the car up and still would open.
if any other suggestions or if there is a way to ghet the door off thanks
zach
Huh. Are you sure that the latch is disengaging?
I can't imagine how you'd get it off without having it open... aside from using a sawzall or something.
"Gimme Fuel,
Gimme Fire,
-Metallica
Drax240z
Guest Daddyrick
The non-running 280Z that I bought for a project car, did have have a key for the doors or rear hatch. The hatch button would go down with no resistance but would not open. Conclusion--- it was locked. We took a thin 10mm open end wrench and from outside the car, removed the 2 bolts holding the latch in place. The hatch then opened, I removed the lock and had a key made.
