Guest Anonymous Posted February 13, 2001 Share Posted February 13, 2001 i just wanted some feed back on this. i had a idea of what i wnat to do to my hood for the whole custom look. before my z i was restobuilding a '74 charger and found what i think to be some of the best hood scoops (shape wise) they are the hood scoops used on barracuda R/Ts. i really want to put a set of these on my z i even found a website that sells them cheap. www.martelbros.com/up/barracuda.htm item# br-200r/l and br-102 i just wanted to know what ou guys think and also ask where i can buy a fiberglass hood for my z to put these on. it is a 79 280zx. thanks much! i just wanted some feedback ------------------ how was I to know that it would do that!..heh..cool...do it again! Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted February 13, 2001 Share Posted February 13, 2001 They look cool, but might be a bear to graph on a stock Z hood, with that center bulge. I not sure anyone makes a ZX hood out of fiberglass, does anyone know? ------------------ http://members.tripod.com/~SnowSurfer/mikekz1.html Quote Link to comment Share on other sites More sharing options...
Guest Fast Frog Posted February 13, 2001 Share Posted February 13, 2001 MSA makes replacement fiberglass hood scoops for the 300ZX Turbo. I grafted one on my 76 hood 7 yrs ago when I had my car still turbocharged. I left it on after I went 383. I think the price at the time was under $100. If you look close at my ride in the Featured Cars section, you can see it. One may want to have a slightly larger scoop in the center of the hood or two smaller scoops, like mine, one on each side. Rick Quote Link to comment Share on other sites More sharing options...
Guest Frank280z Posted February 13, 2001 Share Posted February 13, 2001 I have a hood scoop mounted on my fiber' hood. Just a cowl with the front clipped off. Check it out on the link below. Maybe it will help your decision. Frank ------------------ Build it. Drive it. Improve it. http://www.angelfire.com/extreme2/frankzpage/ Quote Link to comment Share on other sites More sharing options...
Guest Jeff Rimmer Posted February 17, 2001 Share Posted February 17, 2001 www.martelbros.com make replacement fiberglass hoods. Just navigate through their site. It's the only part that they make for the our Z's (240Z 260Z 280Z only) Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted February 17, 2001 Share Posted February 17, 2001 Z-freak, In all my dreaming about a custom hood; I've narrowed it down to a few ideas (by the way I have a 78z). Either using a late 90's Camaro SS scoop, similiar to Franks, using something similiar to the Viper; you know, a small trianglular inlet...I thought that would look good right at the onset of the center bulge in the hood. That would be low provile & effective. My other option was to use the factory hood vents & connect an aftermarket Ram Air Box to the vents & attach a scoop on top of each vent; the scoop I'ld get from a Mid-80's Bi-Turbo Hood 300ZXT, it I could find one in the salvage yards: that would also be low profile, effective & those around would know something under your hood was about to grab hold of'em & not let go. Kevin, [This message has been edited by Kevin Shasteen (edited February 17, 2001).] Quote Link to comment Share on other sites More sharing options...
