P90 Valves
Lurch2461
Availability of the shorter P90 valves is somewhat difficult, yet the longer more standard N42 type are much easier to find.
As I'm using a ground cam and the base diameter is smaller than original, I have been told that I can use the longer valves with standard lash pads.
And if I use the super alloy Ferrea valves, I'm also told I need bronze valve guides.
Q1. Is this correct and what base diameter have I got to have?
Q2. Is a stainless valve a better option?
Thanks,
Dennis in Oz
