Engine Miss
capiii
I have a 79 280zx SCCA race car n/a. The engine started to missfire and run rough at my last race. I will list what we did but we increased the fuel pressure and it ran fine during the race but started loading up and missing during the cool down lap and is still currently running badly.
So we did the following:
changed computer
changed distributor
changed rotor
checked for vacuum leaks
checked timing
changed plugs
changed AFM
checked the tps
checked most ohm readings at the sensors and ecu plug.
changed fuel filter
checked and cleaned grounds
the car is running very rich at idle, really rich. I am picking up a temp sender (goes into thermostat area and feeds the computer) and replacing that today. Seems to miss at all rpms.
Thoughts???
