Guest ttoude Posted March 15, 2010 Share Posted March 15, 2010 (edited) The Question: Ok, been searching and reading since December about switching from a stock "One wire" oil pressure sensor to a "two wire" oil pressure sensor and I cant find anything specific. How does this sucker wire up? One guy wired in a 3 ohm resistor is that necessary for an 81 ECU & 81 motor? Specs: In my case its because of a 81/83 turbo swap into a 1977 na. It came with a "two wire" sensor. But from what I've read the "single wire" type sensor is a really bad option for motors that normally get above 5k rpm. On my car oil pressure sensor harness comes off the lighting/accessory harness that swings around the front from the drivers side along the rad Search Info: But after my reading it seem swapping in a two wire sensor is a must for accuracy sake. Of course after market is probably best but..... Thanks in advance, Mike Edited March 15, 2010 by ttoude Quote Link to comment Share on other sites More sharing options...
Guest ttoude Posted March 16, 2010 Share Posted March 16, 2010 Nothing? Ok thanks have a good one Quote Link to comment Share on other sites More sharing options...
