clear headlight covers? whos are the best
Guest needwaymorespeed
Looking for some headlight covers and wondering whose are the best,does anyone make polycarbonae or are they all plexiglass.
Do the ones that stick on with tape realy stay in place??
Curtis
get the ones with the scews, alot better, i heard that the ones with the tape sometimes fall off, and ya wouldn't want that happening,
i've got the ones with the screws, 3 screws put nicely in place. i prefer the stability
Guest Fast Frog
I've used both clear and smoked lenses. Get the ones that have the metal mounting tabs that screw to the headlight nacel and allow the lens to be screwed to the face of the metal tab. You have to be meticulous when mounting the tabs to get a get a good fit. Be sure that you've got the latest halogen head lamps cause even the clear lenses will reduce your lighting significantly. Motorsport Auto has the lenses with the metal mounting tabs. I'm sure others have them also.
Guest JAMIE T
Fast Frog is right, I've got some covers that are slightly tinted(kind-of bronze tint). I had standard non-halogen lights in the car and could only see small yellowish light on the road in the dark. I just switched to the Sylvania Cool Blue halogen bulbs and WOW what a differance. Very Bright, even with my covers.
Jamie
Deathstar
