WTB: VQ RevUp / Rev-Up electronics (harness/ecm/everything), flywheel/clutch, clutch slave
thisismatt
Looking for pretty much all electronics for an 06 VQ35DE RevUp / Rev-Up edition. I need engine harness, coil harness, main harness, ignition harness, ECM, BCM, IPDM, key/ignition...basically everything to get the motor running in stock form. Or just ECM w/harness & engine harness if I can get them to work standalone. I'm willing to pull parts myself, I just haven't found a donor.
Also need exhaust cam sensors (Exhaust valve timing control position sensors as the FSM calls them). These might be the same as the intake sensors...still trying to check for sure.
Also need flywheel/clutch (both stock are fine), clutch slave.
I'm located in Santa Barbara, CA - willing to drive or pay for shipping.
Edited by thisismatt
