Vr dizzy help
yetterben
Well i am trying to use my N/A 81 dizzy in a vr setup. I have hooked the red wire up to the inner line on the ign line for ms. I have hooked the green wire up to the actual shielding part of that cable. I get no rpm signal. I have tried the green right to a ground same thing. I have set d15 to irq trigger and i have switched the jumper from 1-2 to 3-4 for vr timing on my ms1 ver 3.57 board. Kinda stumped why i cant get a signal at all. Brown wire from ms to - on coil. Kinda stumped.
I also have jp1 set to 1-2 for vr. When i have j1 not jp1 j1 set to 5-6 my spark led is on d15. thats good. now when i touch either the green or red wired buy hand the injectors click and i get a signal. So why cant i get a signal buy cranking the car? yes dizzy is turning.
Edited by yetterben
