cruceno21 Posted June 19, 2010 Share Posted June 19, 2010 (edited) My car was having some power loss off and on... I checked my AFM boot and sure enough a few cracks. So I taped it up and founded a used one to buy. Well the used one has the 77-78 plug hole (my car is a 75). What do people recommend to use to plug the hole? I didn't have something in the garage that fit the hole well. That got me thinking... could I just get an elbow pipe and two rubber couplers to connect the AFM and TB instead of that boot? This would be cheaper than the $50 I am seeing for an AFM boot, and no worries about it cracking again. I have installed a lot of CAIs with those couplers and they are easy to work with and seal up well. So then I searched on eBay and found this: http://cgi.ebay.com/...sQ5fAccessories Has anyone done this? I searched and found nothing. Edited June 19, 2010 by cruceno21 Quote Link to comment Share on other sites More sharing options...
cruceno21 Posted June 19, 2010 Author Share Posted June 19, 2010 Didn't find anything here... but I found this on Zcar and I am going to try something similar. Couplers are 6 or 7 bucks each, and then some cut down CAI tubing from autozone should do the trick I think. http://www.zcar.com/forums/866662/high-flowperformance-intake-boot Quote Link to comment Share on other sites More sharing options...
galderdi Posted July 16, 2010 Share Posted July 16, 2010 On 6/19/2010 at 9:32 PM, cruceno21 said: Didn't find anything here... but I found this on Zcar and I am going to try something similar. Couplers are 6 or 7 bucks each, and then some cut down CAI tubing from autozone should do the trick I think. http://www.zcar.com/forums/866662/high-flowperformance-intake-boot I recently did the throttle body mod. But this meant the space for the boot was too small for the original. So I got some exhaust pipe in the correct diameter, cut it at an angle and welded it back together to get the elbow. I even welded a couple of those smaller pipes on the side for the throttle bypasses. It works well. Quote Link to comment Share on other sites More sharing options...
