Uneven Rear Tire Wear
Hey guys, ive got about 350 miles on the 1jz 240 now and ive noticed the rear passanger tire has started to get inner camber wear. The cars lowered down, dont know how much but low, the drivers rear tire dosnt show any uneven ware so I dont think its a lowering issue.
Is there anyway the toe can be misaligned or adjusted in the rear? Any ideas what may be causing this/how to fix or check it? The wear is noticeable from the outer tread to the center of the tire and more. Its quite a more worn than the driver tire and only in 350 miles so what are the possibilities? Id got to an alignment shop but from what I can see the rear isnt even adjustable, could the whole sub frame be at a slight angle if not bolted down precisely?
I've
-wiggling the tire with it jacked, seemed fine and secure
-cranked down the bolts holding the bushings at the end of the control arm
-pulled the disk off and cleaned all the mating surfaces
Thanks a lot
Edited by Meph
