tightywhitey185 Posted July 13, 2010 Share Posted July 13, 2010 I have a fresh l24 rebuld with exception of the cam rockers and lash pads.All wipe patterns are centered and where they should be and rockers are in there same places as when torn apart. Question:Do I have to use molly greese on the cam being it is not brand new?At this point I have assembled the motor using GM OES assembally lube on pretty much everthing including the cam. Question:I Figured I will just prime my oil pump and then use a drill to prime the motor before start up.Will this be a proper method of pre oiling? Quote Link to comment Share on other sites More sharing options...
