Guest Anonymous Posted June 8, 2002 Share Posted June 8, 2002 I have a 81 280ZXT... its kindda rusted around the fenders....how do I check the frame without jacking it up? i took off tha wheels and looked at the frame and its perfect...is that all i need to check? thanx Z ya lataZ Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 8, 2002 Share Posted June 8, 2002 Take out the seats and carpet and do a little probing with a screw driver on the floor boards, Rust can take hold about anywhere but can usually be found in any area where water or moisture could not easily drain from Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 8, 2002 Share Posted June 8, 2002 Get a flashlight and look at the frame rails underneath. Check for obvious rust and for crumpling. Crumpling indicates that the rails are rotted inside. Check the spare tire well behind the right rear wheel. Finally, open the hood and look under the battery, an area that frequently corrodes on 280ZXs. Quote Link to comment Share on other sites More sharing options...
