Need Help quick
BlueZ31
Recently started having tachometer issues, the needle wont go past 2,200 rpms even at full throttle acceleration and at cruising speeds the rpms are about 2-300 below where they should be (1,200rpms in 5th gear at 55mph on a stock 87 N/A is not right) i changed out my coil which temporarily solved the problem but a week later the issues come back to haunt me, along with a very loud humming noise from the drivers side dash area present only while the engines running.
Anyone had similar issues or know of a fix?
