ktm Posted September 5, 2010 Share Posted September 5, 2010 I am in the process of rewiring my car after an electrical short that almost caused significant, if not catastrophic, burn damage. As part of this project I am relocating the battery to the rear deck, using a Deka ETX30L "light weight" battery, and installing a cut off switch. The battery will be located in the center of the deck about 6 inches from the luggage riser trim and mounted flat. To those that have relocated their batteries and installed a cutoff switch, where did you mount the switch? Quote Link to comment Share on other sites More sharing options...
Challenger Posted September 5, 2010 Share Posted September 5, 2010 (edited) I'm considering using a large relay with a small switch just to simplify the wiring being that it's 2 gauge wire going to my battery. My batter is in the left rear of my hatch area. Under the raised floor and behind where the plastic panel will be. Edited September 5, 2010 by Challenger Quote Link to comment Share on other sites More sharing options...
ktm Posted September 9, 2010 Author Share Posted September 9, 2010 Thanks Challenger. I went ahead and mounted my cutoff switch on the firewall over the battery tray area. I had to remove the battery tray in order to mount the switch. It is a good convenient location. Quote Link to comment Share on other sites More sharing options...
