JDM Posted December 28, 2010 Share Posted December 28, 2010 I have a 1975 280Z with LS 1 installed. I bought the car as it is. Now thereis no AC compressor on the car. Could I used Stock LS1 AC compressor with the bracket? Or is there anyone making special AC compressor braket, pully, and belt for it. Help!!!!!!!!! JD Quote Link to comment Share on other sites More sharing options...
Ls240sx Posted December 28, 2010 Share Posted December 28, 2010 What are you using for mounts? If you are using JohnsCars mounts: "AC compressor mount and drive: New aluminum high efficiency compressor, made in Japan (serpentine belt drive). I do not supply or make the hoses except for factory air conditioned cars as there are too many variations. Most hydraulic hose or AC shops can make you a set when you drive the car to them. The GM factory AC compressor will not clear my mounts so I designed a custom unit. My package includes all mounting brackets and hardware, uses stock GM belt ,freight paid - $450.00. Hose set, drier, pressure switch for "280" models with factory air is now available, $200.00 (only with my A/C kit)." If you are using custom mounts im sure you could use a stock bracket. Quote Link to comment Share on other sites More sharing options...
