Ebay Headers
  On 1/20/2011 at 9:07 PM, Cable said:
Are you planning on doing a turbo setup using these headers in the flipped/reverse position?
Its a very feasible possibility. I just don't like to buy things twice. I'll probably just run it N/A for a while, but these headers are a good deal (in my mind).
Even if i have to run them flipped. I'd REALLY like to make the passenger's side fit with a forward/down. It will take quite a bit of fabrication, and probably relocation of the mount on the passenger's side, and use a clamshell like the drivers side. Worth the work? Probably not. But I can do the work cheap, where as building a set of headers would be essssspensive. I'd probably do mild steel and have them coated, which I'd be in the 4-500 range at that point. There are still a lot of unknowns right now.
