R200 Question
JG240z
I have an R200 out of a 90-93 NA 300zx. Does anyone know if this rear end with work in my 240z when doing my 302 SBF swap? I am not sure if this is the same R200 as the one that came in the 280zx. Any help would be greatly appreciated!.
Yes it will. But it is not a direct bolt in. Check out http://www.modern-motorsports.com/catalog/product_info.php?products_id=74&PHPSESSID=e4c4cdce0da0661dae77c16c27d4de83
Edited by ozzzzz
Thanks for the info. Does that kit make it a bolt in project, or is there still some modification needed with that kit? Thanks again!
You also need cv axles and adapters. Theres a sticky in the drivetrain forum. I have a r230 ,
I had to remove some metal above the differencial housing. I am not sure if this needs to done on the r200?
Edited by ozzzzz
The 240Z came with an R180, the main difference is the mustache bar and maybe the nose length, some r 200's are long nose and short nose, about 1 1/2" difference. you will need the mustache bar from a r 200 and maybe have to fabricate a front mount, you are going to have to make a driveshaft to fit either way more than likely. It isnt a hard swap over and very well worth the extra strength of the r 200. You should be able to use your half shafts with the r 200 i think, they just snap in and out of the housings.
