Oil on spark pulgs.
Hi i am geting oil blow buy on my spark pulgs. Dose any one think it might be something else them the piston rings?
My car also idles at 1000 rpms for like a min then drops down below 500 rpms. I know i need to rebuild the engine so dose any one know where the best place to get a rebuild kit for a 77 280z?
Edited by 77 Blule 280z
What makes you think you need an engine rebuild?
How do you know "oil" is on the plugs?
How many spark plugs are involved? Which ones?
What are the compression numbers?
What color is the smoke out of the tailpipe?
Get the idea??? B)
Get the idea??? B)
The plugs are black thats why i think its oil.
All six plugs are black.
I dont know the compression.
Its got a kind of blue look to the smoke and when i rev it up it shoots black soot out spots on the ground.
It sounds like overfueling/running rich.
What engine/ fuel system do you have?
What is the history on the car? Milage?
Pictures?
Its the stock l28 77 280z. And its the stock Fuel system that came with the car.
I bought the car from the frist owner about six mouths ago. The lady i bought it from said it has ony run over once so if thats true it has 160,000 on the engine. I planed on rebuiled it and geting rid of the few rust spots but if i have to do the engine stuff frist.
I toke pics of my engine and of a spark plug. And the one with the black on the concret wall is back up to it and the exhust left that on the wall.
OK so should i do a timeing check to?
I would recommend that the timing be checked and set to the factory recommended setting. If you are looking for some good tips on getting your car running like it should, check out http://atlanticz.ca/zclub/techtips/reviving/index.html, especially the section about "Tune the car" (toward the bottom of the page).
Thanks that helped alot i will see if i can fix the promblem.
