jap tin Posted March 16, 2011 Share Posted March 16, 2011 I have a 71 240Z, produced in 11-70. The brake master cylinder has the brake ports opposite the newer model Z's. The front port is for the front brakes, the rear is for the rear brakes. Can I swap in a 72 & up master cylinder with the front port going to the rear brakes and the rear port going to the front brakes and swap the lines going to the master cylinder or will I run into trouble with the push rod depth between the master cylinders? Thanks. Quote Link to comment Share on other sites More sharing options...
psdenno Posted March 17, 2011 Share Posted March 17, 2011 When my early style original M/C went bad on my '71 Z, I replaced it with the later style due to cost and availability. All that was required was to route the brake lines to the appropriate reservoir - which is opposite from the early style M/C. No other issues. Dennis Quote Link to comment Share on other sites More sharing options...
jap tin Posted March 17, 2011 Author Share Posted March 17, 2011 Thanks Dennis. Quote Link to comment Share on other sites More sharing options...
jap tin Posted May 6, 2011 Author Share Posted May 6, 2011 Wound up finding new old stock from a dealer back east. Figured the original made it 40 years, might as well get another. Quote Link to comment Share on other sites More sharing options...
